Moving content of a window affects to moving content in other windows
    • Moving content of a window affects to moving content in other windows
      Hello to everyone,
      my problem is following: here is a simple code with 3 simple windows with content inside the windows that can be moved using motion support.
      1st window - content can be moved circularly.
      2nd window - content can be moved horizontally.
      3rd window - content can be moved vertically.
      If I move content in 2nd and 3rd window all is fine and moves as it should.
      But if I move content in 1st window with circular motion support and after that I try to move content in other windows then begins the following:
      2nd window - content moves much faster (WM_MOTION_MOVE: pInfo->dx returns much higher values);
      3rd window - content doesn't move at all (WM_MOTION_MOVE: pInfo->dy returns 0).
      Here is the code using latest simulation package v6.26:
      1. #include "DIALOG.h"
      2. int x1, y1, ang1 = 0;
      3. int x2 = 10;
      4. int y3 = 10;
      5. void _cbWin1(WM_MESSAGE * pMsg) {
      6. WM_MOTION_INFO * pInfo;
      7. switch (pMsg->MsgId) {
      8. case WM_MOTION:
      9. pInfo = (WM_MOTION_INFO *)pMsg->Data.p;
      10. switch (pInfo->Cmd) {
      11. case WM_MOTION_INIT:
      12. pInfo->Flags = WM_CF_MOTION_R | WM_MOTION_MANAGE_BY_WINDOW;
      13. break;
      14. case WM_MOTION_MOVE:
      15. ang1 += pInfo->da;
      16. WM_InvalidateWindow(pMsg->hWin);
      17. break;
      18. case WM_MOTION_GETPOS:
      19. pInfo->xPos = ang1;
      20. break;
      21. }
      22. break;
      23. case WM_PAINT:
      24. GUI_SetBkColor(GUI_WHITE);
      25. GUI_Clear();
      26. GUI_SetColor(GUI_BLACK);
      27. GUI_DispStringHCenterAt("Radial motion", 100, 10);
      28. x1 = (int)(GUI__SinHQ(ang1 * 100) * 85 * 0.0000152587890625f) + 100;
      29. y1 = (int)(GUI__CosHQ(ang1 * 100) * 85 * 0.0000152587890625f) + 100;
      30. GUI_SetColor(GUI_RED);
      31. GUI_FillCircle(x1, y1, 10);
      32. break;
      33. default:
      34. WM_DefaultProc(pMsg);
      35. break;
      36. }
      37. }
      38. void _cbWin2(WM_MESSAGE * pMsg) {
      39. WM_MOTION_INFO * pInfo;
      40. switch (pMsg->MsgId) {
      41. case WM_MOTION:
      42. pInfo = (WM_MOTION_INFO *)pMsg->Data.p;
      43. switch (pInfo->Cmd) {
      44. case WM_MOTION_INIT:
      45. pInfo->Flags = WM_CF_MOTION_X | WM_MOTION_MANAGE_BY_WINDOW;
      46. break;
      47. case WM_MOTION_MOVE:
      48. x2 += pInfo->dx;
      49. if (x2 < 10)
      50. x2 = 10;
      51. if (x2 > 290)
      52. x2 = 290;
      53. WM_InvalidateWindow(pMsg->hWin);
      54. break;
      55. case WM_MOTION_GETPOS:
      56. pInfo->xPos = x2;
      57. break;
      58. }
      59. break;
      60. case WM_PAINT:
      61. GUI_SetBkColor(GUI_WHITE);
      62. GUI_Clear();
      63. GUI_SetColor(GUI_BLACK);
      64. GUI_DispStringHCenterAt("Horizontal motion", 150, 10);
      65. GUI_SetColor(GUI_BLUE);
      66. GUI_FillCircle(x2, 50, 10);
      67. break;
      68. default:
      69. WM_DefaultProc(pMsg);
      70. break;
      71. }
      72. }
      73. void _cbWin3(WM_MESSAGE * pMsg) {
      74. WM_MOTION_INFO * pInfo;
      75. switch (pMsg->MsgId) {
      76. case WM_MOTION:
      77. pInfo = (WM_MOTION_INFO *)pMsg->Data.p;
      78. switch (pInfo->Cmd) {
      79. case WM_MOTION_INIT:
      80. pInfo->Flags = WM_CF_MOTION_Y | WM_MOTION_MANAGE_BY_WINDOW;
      81. break;
      82. case WM_MOTION_MOVE:
      83. y3 += pInfo->dy;
      84. if (y3 < 10)
      85. y3 = 10;
      86. if (y3 > 290)
      87. y3 = 290;
      88. WM_InvalidateWindow(pMsg->hWin);
      89. break;
      90. case WM_MOTION_GETPOS:
      91. pInfo->yPos = y3;
      92. break;
      93. }
      94. break;
      95. case WM_PAINT:
      96. GUI_SetBkColor(GUI_WHITE);
      97. GUI_Clear();
      98. GUI_SetColor(GUI_BLACK);
      99. GUI_DispStringHCenterAt("Vertical motion", 50, 10);
      100. GUI_SetColor(GUI_GREEN);
      101. GUI_FillCircle(50, y3, 10);
      102. break;
      103. default:
      104. WM_DefaultProc(pMsg);
      105. break;
      106. }
      107. }
      108. void MainTask(void) {
      109. GUI_Init();
      110. WM_MULTIBUF_Enable(1);
      111. WM_SetDesktopColor(GUI_BLACK);
      112. WM_SetScreenSize(1024, 768);
      113. WM_CreateWindow(100, 100, 200, 200, WM_CF_SHOW, _cbWin1, 0);
      114. WM_CreateWindow(400, 100, 300, 100, WM_CF_SHOW, _cbWin2, 0);
      115. WM_CreateWindow(800, 100, 100, 300, WM_CF_SHOW, _cbWin3, 0);
      116. WM_MOTION_Enable(1);
      117. while (1) {
      118. GUI_Delay(50);
      119. }
      120. }
      What am I doing wrong?
      Alex.
    • Hi Alex,
      Thank you for reporting this issue! The issue only occurs when WM_MOTION_R would be used initially and then vertical/horizontal motion afterwards. It will be fixed with the next bugfix release.
      If you need a fix for this as soon as possible, please have a look at the attached file. An internal function pointer was not reset from radial movements back to XY movements which is what I added to your sample.
      Florian
