[SOLVED] Unable to change the Serial numbers of the Board via JLink Commander
  • [SOLVED] Unable to change the Serial numbers of the Board via JLink Commander
    We are unable to change the Serial Number using the JLink Commander, an an auto assignment happens irrespective of writing to the any of the address location
    For example
    wconf 8 01
    wconf 9 C1
    wconf A A4
    wconf B 31
    and when we read back after rebooting the board. We get FF FF FF FF instead of the values written
    Board : RENESAS EK-RA4M1
    Please help us with the resoltuon of workaround
    We see an issue with v7.66e and higher
    wiki.segger.com/J-Link-OB-S124-Renesas#Serial_number
  • What makes you think that you can change the S/N of the J-Link OB?
    As the wiki article (you have posted a link to) clearly says:
    Initially, all J-Link-OB-S124 reported the same S/n (831004110) and via a FW update in a new version, the S/N gets „auto-corrected“ to a generated one.
    Actually, you are messing around with undocumented regions of the J-Link config area, so you are actually lucky that you did not brick your OB forever…
