[SOLVED] "No debuggers were discovered" error coming while flashing using nrfjprog util
  • [SOLVED] "No debuggers were discovered" error coming while flashing using nrfjprog util
    Hi All,
    I am new in using SEGGER tools. For my current project, I am using nRF5340 DK(PCA10095 2.0.0) as my target and I wanted to flash my demo application or any existing sample application via onboard SEGGER J-Link programmer/debugger using nrfjprog. When I tried to flash my application using the command "nrfjprog -f NRF53 --program /ncs/nrf/samples/keys/hw_unique_key/build/zephyr/zephyr.hex --chiperase --log" I am getting following error: "ERROR: No debuggers were discovered."
    Note: I am doing all this from a Docker image.
    I am pasting the log taken from the nrfjprog command.
    [ info]: --------------------------------------------------------------------------------
    [ info]: nrfjprog -f NRF53 --program /ncs/nrf/samples/keys/hw_unique_key/build/zephyr/zephyr.hex --chiperase --log
    [ info]: nrfjprog version 10.17.2 external
    [ info]: Load library at /opt/nordic/nrf-command-line-tools/lib/libnrfjprogdll.so.
    [ info]: Library loaded, loading member functions.
    [ info]: Member functions succesfully loaded.
    [debug]: [ Client] - open
    [debug]: [ Client] - start
    [ info]: [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 41abb62e-f1f7-4172-96b8-0b5951500b3a.
    [debug]: [SeggerBackend] - Logger sink registered in Segger backend logger
    [debug]: [ JLink] - Logger sink registered in JLink logger
    [debug]: [ nRF53] - open
    [debug]: [ nRF53] - just_check_family
    [debug]: [SeggerBackend] - open_dll
    [debug]: [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [ info]: [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.70.3.
    [trace]: [ Client] - Command open executed for 35 milliseconds with result 0
    [debug]: [ Client] - config
    [trace]: [ Client] - Command config executed for 1 milliseconds with result 0
    [debug]: [ Client] - enum_emu_snr
    [ info]: [SeggerBackend] - Library loaded, loading member functions.
    [ info]: [SeggerBackend] - Member functions succesfully loaded.
    [debug]: [SeggerBackend] - Set batch mode
    [debug]: [SeggerBackend] - dll_version
    [ info]: [SeggerBackend] - Segger dll version 7.70.c loaded.
    [trace]: [ Worker] - Command open executed for 33 milliseconds with result 0
    [debug]: [ nRF53] - config
    [trace]: [ Worker] - Command config executed for 1 milliseconds with result 0
    [debug]: [ nRF53] - enum_emu_con_info
    [debug]: [SeggerBackend] - is_connected_to_emu
    [debug]: [SeggerBackend] - enum_emu_con_info
    [trace]: [ Client] - Command enum_emu_con_info executed for 45 milliseconds with result 0
    [trace]: [ Worker] - Command enum_emu_con_info executed for 45 milliseconds with result 0
    [debug]: [ nRF53] - close
    [debug]: [SeggerBackend] - close
    [debug]: [SeggerBackend] - disconnect_from_emu
    [debug]: [SeggerBackend] - Segger Backend closed.
    [debug]: [ nRF53] - nRF family DLL closed
    [trace]: [ Client] - Command close executed for 11 milliseconds with result 0
    [debug]: [ Client] - terminate
    [trace]: [ Client] - Command terminate executed for 0 milliseconds with result 0
    [trace]: [ Worker] - Command close executed for 11 milliseconds with result 0
    [trace]: [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [trace]: [ Worker] - Executed 5 commands for 90 milliseconds
    [debug]: [ Client] - Worker process exited with code: 0
    [debug]: [ Client] - Child process terminated with result 0
    [trace]: [ Client] - Executed 5 commands for 92 milliseconds
    I followed some discussions and tried to execute JLinkExe but that doesn't help but throws another error. Below is the output of that.
    SEGGER J-Link Commander V7.70c (Compiled Aug 18 2022 17:30:05)
    DLL version V7.70c, compiled Aug 18 2022 17:29:50
    Connecting to J-Link via USB..../JLinkGUIServerExe: error while loading shared libraries: libfreetype.so.6: cannot open shared object file: No such file or directory
    FAILED: Cannot connect to J-Link.
    Any kind of support is highly appreciated. Feel free to ask any further informations on my steps and on about the target details.
    The post was edited 2 times, last by vdb ().
    Did you add the required rules file to allow J-Links to be discovered via USB?
    If you have not added the 99-jlink.rules file (part of the J-Link Software Pack) to your linux system, you would have to call any
    application using the J-Link DLL (e.g. nrfjprog) as with sudo (as super user).
    J-Link Software Pack:
    Could you please check this?
    On a side note:
    nrfjprog is not a SEGGER application but developed and maintained by Nordic Semiconductor.
  • Hi fabian,
    Thank you for reply and above provided suggestion. I have not added any rules file in to the Linux system. But now I added the 99-jlink.rules file from the J-Link Software Pack to /usr/lib/udev/rules.d. But the result os the same.
    Output:
    root@fcc4c8f2d60e:/in3/c/demo/key-management/build# cp /opt/SEGGER/JLink/99-jlink.rules /usr/lib/udev/rules.d/
    root@fcc4c8f2d60e:/in3/c/demo/key-management/build# nrfjprog -f NRF53 --program zephyr/zephyr.hex --chiperase
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
  • Very much sounds like a setup issue, not a product defect.
    We recommend to try on a 2nd machine and maybe a Windows VM etc. just for testing.
    Also, for Linux we recommend to use the DEB / RPM installers instead of the tgz file, as the installers take care of the rules file and other setup.
    We will consider this thread as closed.
