[SOLVED] SES 6.32 simulator not correctly showing variable values
  • [SOLVED] SES 6.32 simulator not correctly showing variable values
    I'm having a hard time understanding the rules for when SES does and does not provide information on variables. The attached screenshot shows that variable 'ptr' correctly loaded a value from 'result.value.v_voidPtr', so why is this value not showing in the union for 'result'? Variables also keep appearing and disappearing from the listings of 'locals' and 'autos' even when they are still in scope. Are there some kind of additional settings I need to enable?
    Sounds like code optimization is off. Could you check if any optimization level is active?
    For debugging we recommend level 0.
    great to hear that you are up and running again.
