[SOLVED] Difference between JLink and ST-link
  • [SOLVED] Difference between JLink and ST-link
    As a beginner I was wondering what the difference is between jlink and stlink. Both can step through the code and debug so why opt for JLink? From what I've seen setting up JLink even takes more effort.
  • Why opt for segger embedded studio?
    Well where to start.
    - Independence from Silicon Vendors
    - Over 10000 different target devices supported from nearly all silicon vendors
    - Significantly faster download speed
    - Significantly faster performance overall
    - Support for Advanced debug features
    - Supported in most popular IDEs and debuggers
    - Multiple different models to fit different use cases/budgets
    - Flash Breapoints (SEGGER patented)
    - SEGGER RTT -> extremely fast I/O interface
    - Multiple CPU Architectures supported (Arm, RISC-V, RX...
    and on and on...
    Most information about this can be found on our website.
    Here are some links:
    segger.com/products/debug-probes/j-link/
    segger.com/products/debug-prob…nk/models/model-overview/
    We did not become the market leader by being "just as good" as competitors ;)
    How do you come to that conclusion? What IDE are you using?
    In most IDEs and debuggers the setup is straightforward and J-Link is either supported natively, so you only have to switch it on in project options, or a plugin or similar is available to make use of our GDB Server as fallback (which is still significantly faster and more easy to use than any other GDB only solutions).
    An overview of some of the IDEs that support J-Link can be found here:
    segger.com/products/debug-prob…erview-of-supported-ides/
