Hi segger experts,
Recently, I've met the following case and i've no idea to fix that, could you please help check that?
Issue:
If I choose the official RV32 as the device for my risc-v platform, then it can be accessed via Jlink-cJTAG; but if I define my own device name in the JLinkDevices.xml file, it cannot be accessed.
Steps:
1. Select the official RV32 as the device.
![](https://forum.segger.com/index.php/Attachment/5149-selectRv32-png/?s=99b4825a3e2bf4230225e07e3b4fad5671356d57)
2. You could see my risc-v platform can be accessed via cJTAG.
3. Now I add my own device into the JlinkDevices.xml, meanwhile named the Vendor is "VendorTest" and the device name is "TestDevice" just as the following shows:
![](https://forum.segger.com/index.php/Attachment/5151-definedDevice-png/?s=99b4825a3e2bf4230225e07e3b4fad5671356d57)
4. Select the TestDevice.
![](https://forum.segger.com/index.php/Attachment/5152-selectDefinedDevice-png/?s=99b4825a3e2bf4230225e07e3b4fad5671356d57)
5. My risc-v platform can not be accessed!![](https://forum.segger.com/index.php/Attachment/5153-failure-png/?s=99b4825a3e2bf4230225e07e3b4fad5671356d57)
I need to add my own device name into the JlinkDevice.xml so that I can use my flashloader, but now it sees there exists problem to access the risc-v core via cJTAG in such way
Have you met such issue before and how to fix that?
Thanks in advance,
Gavin
Best Regards,
Issue:
Steps:
![:(](https://forum.segger.com/wcf/images/smilies/sad.png)
Thanks in advance,
Gavin
Best Regards,
