When I try to read my LPC55S69 flash memory with JFlash V7.66b and a J-Link I receive the following error: 'Failed to read back target memory'. Nevertheless, there's no problem when I use J-Mem V7.66b and the same J-Link. This is what the log file says:
Connecting ...
- Connecting via USB to probe/ programmer device 0
- Probe/ Programmer firmware: J-Link V9 compiled May 7 2021 16:26:12
- Device "LPC55S69_M33_0" selected.
- ConfigTargetSettings() start
- Disabling flash programming optimizations: Compare, SkipBlankDataOnProg
- ConfigTargetSettings() end
- InitTarget() start
- InitTarget() end
- Found SW-DP with ID 0x6BA02477
- DPIDR: 0x6BA02477
- CoreSight SoC-400 or earlier
- Scanning AP map to find all available APs
- AP[3]: Stopped AP scan as end of AP map has been reached
- AP[0]: AHB-AP (IDR: 0x84770001)
- AP[1]: AHB-AP (IDR: 0x84770001)
- AP[2]: JTAG-AP (IDR: 0x002A0000)
- Iterating through AP map to find AHB-AP to use
- AP[0]: Core found
- AP[0]: AHB-AP ROM base: 0xE00FE000
- CPUID register: 0x410FD213. Implementer code: 0x41 (ARM)
- Feature set: Mainline
- Found Cortex-M33 r0p3, Little endian.
- FPUnit: 8 code (BP) slots and 0 literal slots
- Security extension: implemented
- Secure debug: enabled
- CoreSight components:
- ROMTbl[0] @ E00FE000
- [0][0]: E00FF000 CID B105100D PID 000BB4C9 ROM Table
- ROMTbl[1] @ E00FF000
- [1][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
- [1][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
- [1][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
- [1][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
- [0][1]: E0040000 CID B105900D PID 000BBD21 DEVARCH 00000000 DEVTYPE 11 Cortex-M33
- SetupTarget() start
- SetupTarget() end
- Target interface speed: 2000 kHz (Auto)
- VTarget = 3.329V
- InitTarget() end
- DPIDR: 0x6BA02477
- AP map detection skipped. Manually configured AP map found.
- AP[0]: AHB-AP (IDR: Not set)
- AP[0]: Core found
- SetupTarget() end
- Executing init sequence ...
- Executing Reset (0, 0 ms)
- ResetTarget() start
- Reset strategy selected in debugger ignored. Performing device specific reset.
- Reset handler addr: 0x00003974
- ResetTarget() end
- AfterResetTarget() start
- AfterResetTarget() end
- Initialized successfully
- Found 1 JTAG device. Core ID: 0x6BA02477 (None)
- Connected successfully
Reading target memory (0x00000000 - 0x0009DDFF) ...
- Start of preparing flash programming
- End of preparing flash programming
- ERROR: Failed to read memory (0x20000 bytes @ address 0x00000000)
- Start of restoring
- End of restoring
- ERROR: Failed to read back target memory
Disconnecting ...
- Disconnected
Connecting ...
- InitTarget() end
- DPIDR: 0x6BA02477
- AP[0]: Core found
- SetupTarget() end
- VTarget = 3.329V
- InitTarget() end
- DPIDR: 0x6BA02477
- AP[0]: Core found
- SetupTarget() end
- ResetTarget() end
- End of restoring
Disconnecting ...
- Disconnected
