[SOLVED] When the software is ported to FreeRTOS, compilation prompt error: #35: #error directive: This port can only be used when the project options are configured to enable hardware floating point support.
  • [SOLVED] When the software is ported to FreeRTOS, compilation prompt error: #35: #error directive: This port can only be used when the project options are configured to enable hardware floating point support.
    When Keil migrated project, prompt at compile time,error:#35: #error directive: This port can only be used when the project options are configured to enable hardware floating point support.How to set in embedded?
    You can change the floatingpoint settings in Embedded Studio in project options under Code > Code Generation > ARM FP ABI Type
    There set it to hard and rebuild.
    Should you still get the error could you provide the source file where it happens so we can see the dependency that is required?
