[SOLVED] No reaction after selecting Jlink
  • [SOLVED] No reaction after selecting Jlink
    Hi expert,
    I am trying systemview3.2 with Jlink plus, but after i select Jlink and click OK, there is no further reaction(normally it should remainder user to select MCU device), the figure is as below.
    per my understanding, though my MCU program is not right, the system view still should display the window to select chip part number.
    I tried version V3.12, it work well, so does it mean the system view have version requirement for the driver in MCU side?
    Per default the new SystemView versions will show this pop-up only once on the first SystemView start.
    After that you can find that configuration window under Target->Recorder Configuration.
    Also we recommend to use the latest SystemView version if possible as for older versions no support will be provided.
