[SOLVED] Adding one solution\project to another solution
  • [SOLVED] Adding one solution\project to another solution
    when I'm adding any solution or project, e.g. static library, to another solution, e.g. executable, I have manually copy all preprocessor derictives and includes. Is it correct way to use static libraries in SES? It's not very comfortable. Is there any tool (or are there plans to develop this tool in future) to import all preprocessors together with solution when adding to current project?
    If you add an existing project to your current solution all project options that you may have set in the original project will be kept on project level and not propagate up into the solution.
    This is simply to not break the existing solution setup and all the other projects that are in that solution.
    So the correct approach would be to move all preprocessor settings and include paths to solution level, so whatever projects you add to your current solution, they will be able to inherit the solution settings.
