[ABANDONED] Microchip ATSAMG55J19 Reset Strategy 2 Not Asserting Reset#
  • [ABANDONED] Microchip ATSAMG55J19 Reset Strategy 2 Not Asserting Reset#
    I'm using a Jlink Ultra on a Cortex-M4 based ATSAMg55J19. The JLink DLL is 7.60c
    The default reset strategy sometimes fails to gain control of the processor after reset. I can mitigate this by using RX 100 from JlinkExe.
    However, I'd like to pull Reset# low to get (hopefully) better results and also to reset other devices in the system which are also wired to Reset#. See below.
    A second question is how to make Ozone set the reset type and reset delay.
    Dale
    [edt@sleet JLink]$JLinkExe
    SEGGER J-Link Commander V7.60c (Compiled Jan 7 2022 16:13:49)
    DLL version V7.60c, compiled Jan 7 2022 16:13:33
    Device "ATSAMG55J19A" selected.
    Connecting to target via SWD
    DPIDR: 0x2BA01477
    CoreSight SoC-400 or earlier
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    [0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
    [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
    [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
    [0][3]: E0000000 CID B105E00D PID 003BB001 ITM
    [0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
    Cortex-M4 identified.
    J-Link>rst 2
    Reset type RESETPIN: Resets core & peripherals using RESET pin.
    J-Link>reset
    Reset delay: 0 ms
    Reset type RESETPIN: Resets core & peripherals using RESET pin. <----------------- Does NOT Pull Reset# low,
    J-Link>ishalted
    CPU is halted (PC = 0x00404848).
    J-Link>r0 <------------------------------------------------------------------------------- Does Pull Reset# low
    J-Link>r1 <--- Reset# back high
    We are not able to reproduce this.
    rst 2 + reset will pull reset low, but just for a very small amount of time.
    I would suggest to use an Oscilloscope to check the reset line to verify this on your side.
