[SOLVED] Ozone in MacOS 12.3
  • Hi Thomas,
    last version that we tested Ozone with was 11.6.4.
    12.3 should also work, but it is not tested by us yet as demand was not existent.
    But if Apple did not change anything major (again). Everything should be working as expected.
    If it helps, so far we have not received any macOS bug reports with V12.x and Ozone.
  • Hi ,
    Apple did change something on MacOS Monterey which broke fonts. For example, mono spaced fonts as used in the memory window are not displayed properly.
    We are working on a work-around for that.
    In case you see a different issue with Ozone, could you please open a ticket in our ticket system? This can be found here: segger.com/ticket.
    -- Alex
