[SOLVED] J-link not communicating with target device
  • [SOLVED] J-link not communicating with target device
    I cannot make the J-link Segger connect to a microcontroller (Vorago) that uses the Cortex-M4.
    Details about microcontroller’s setup:
    • The power supplies (3.3 V, 1.5 V, VRef (3.3V), 5V) on the board all read the expected values, after using a volt meter
    • The J-link was programmed (through J-link commander) with the “power on” command to output 5 V on pin 19. The 5V can be read on the target’s (JTAG/VDD) pin as 5V.
    • Pin 19 on the J-link was measured with an oscilloscope and it does output a 5V value as expected.
    • The J-link is directly connected to the target through a ribbon cable provided by Segger.
    • The LED that indicates that the target in ON is “ON.”
    • Already followed the troubleshooting instructions from chapter 19 of the J-link/J-Trace (UM08001) & Keil MDK.
    • Followed the power supply instructions and proper jumper connections from the manufacturer of the microcontroller
    • The JTAG pins (on the target device) output the expected voltage relative to the VTRef=3.3 V (on pin 1):
    All even pins (except pin 2) =Gnd.
    Pins: 2, and all add pins are equal to VTRef=3.3V(pin 1).
    Pin 7: 2.8 V.
    Pin 19 is the target voltage supply pin, which reads 3.0V without the J-link connected, and 5V when the J-link is connected (read from JTAG/VDD pin on the board).
    I attempt to communicate through the J-Link commander , the J-link RTT, and through Keil MDK.
    This is the information of the J-link:
    DLL version V7.56b
    Hardware version: V11.00
    S/N:261014505
    **The J-link commander is able to sense the VTref of the microcontroller as 3.3 V, and I can program the supply voltage of the
    the J-link using J-link commander. (Thus the J-link EDU is fully functional), but it still cannot
    connect to the target.
    *** For the J-link RTT: TheRTT control block is correct in accordance to the *.map output file for the microcontroller.
    Different speed frequencies were also used below and above the J-Link's specifications, and the connection still failed.
    ** No previous source code has been loaded into the device.
    I look forward to hear troubleshooting tips, beyond "Check the connection," because as stated above that was already followed.
    thank you in advance.
  • wiki.segger.com/Debug_Probes_-…6_J-Trace#Troubleshooting
    wiki.segger.com/J-Link_cannot_connect_to_the_CPU
    We recommend to check with a known as good eval board. If the basic steps from the wiki article above work and J-Link Commamder can connect, you know that the J-Link is good but your HW is not, so you have a point to start searching.
