[ABANDONED] Ozone -- Top of stack - no unwinding symbols at <address>
  • [ABANDONED] Ozone -- Top of stack - no unwinding symbols at <address>
    Debugger: Ozone 3.26b
    RTOS: embOS 5.14.0.0
    Compiler: gcc-arm-none-eabi-10-2020-q4-major or gcc-arm-none-eabi-7-2018-q2-update (Issue identical on with both tool chains)
    Host OS: macOS Big Sur 11.6.2 or Ubuntu Linux 18.04 LTS (Issue identical on both macOS and Linux)
    When I debug using Ozone, the call stack is effectively empty with only the current execution position.
    There is a message "Top of stack - no unwinding symbols at <address>"
    When I debug using Eclipse + Embedded C/C++ J-Link Debugging plugin + JLinkGDBServer, the call stack, local variables, global variables all work correctly.
    Here is a screen shot of the Ozone Call Stack window.
    Your suggestions are welcome and appreciated.
    The post was edited 1 time, last by morrisrx: Tested second compiler tool chain. Same problem. ().
    Could you provide a example project for reproduction that would run on an eval board?
