Reducing size of xbf font
    • Reducing size of xbf font
      I am trying to create font using specific Chinese and English characters.
      I am generating xbf using FontCvt and converting it to array using Bin2C tool.
      But final created array has much larger size possibly due to Chinese characters are not continuous characters as in English.
      Is there any way by which I can reduce size of my converted array?
      Any help regarding this will really be helpful.
      Attaching my xbf and c file for reference.
      • test.zip
        (43.65 kB, downloaded 212 times, last: )
      The post was edited 1 time, last by amar.sanas ().
      Due to the large amount of Chinese characters, a Chinese font is much larger than a font with only Latin characters. Every Chinese character has its own bitmap.
      What you could do to save memory is applying a pattern file to the font in the Font Converter. This would ensure only the characters that you need are added to the XBF font.
      Make sure to use "Extended" fonts in the Font Converter instead of "Standard" fonts, since extended fonts are more memory-efficient. Another way to reduce memory would be to use 1bpp fonts instead of 2bpp or 4bpp anti-aliased fonts.
      If the XBF file is still too big, I would recommend storing it on external memory.
      Florian
