[SOLVED] JLinkGDBServer -xc reports "Unsupported remote command" for all commands in gdb script
  • [SOLVED] JLinkGDBServer -xc reports "Unsupported remote command" for all commands in gdb script
    I'm working in an environment that supports debugging many embedded projects. I'm attempting to run JLinkGDBServerCL, but I need to avoid polluting `~/.gdbinit` as much as possible. Helpfully, JLinkGDBServer provides the `-xc` switch for executing gdb command files. Unfortunately, none of the commands seem to be accepted when I use this switch:
    1. SEGGER J-Link GDB Server V7.54d Command Line Version
    2. JLinkARM.dll V7.54d (DLL compiled Sep 28 2021 16:18:25)
    3. WARNING: Unknown command line parameter /home/vagrant/Documents/product/build/product/bin/product_main_application.out found.
    4. Command line: -nosilent -device AT91SAM7S256 -endian little -if JTAG -speed auto -port 2159 -swoport 2160 -telnetport 2161 -timeout 15000 -singlerun -halt -xc /home/vagrant/Documents/product/build/product/etc/gdb/reset.gdbinit -ir -vd /home/vagrant/Documents/product/build/product/bin/product_main_application.out
    5. -----GDB Server start settings-----
    6. GDBInit file: /home/vagrant/Documents/product/build/product/etc/gdb/reset.gdbinit
    7. GDB Server Listening port: 2159
    8. SWO raw output listening port: 2160
    9. Terminal I/O port: 2161
    10. Accept remote connection: yes
    11. Generate logfile: off
    12. Verify download: on
    13. Init regs on start: on
    14. Silent mode: off
    15. Single run mode: on
    16. Target connection timeout: 15000 ms
    17. ------J-Link related settings------
    18. J-Link Host interface: USB
    19. J-Link script: none
    20. J-Link settings file: none
    21. ------Target related settings------
    22. Target device: AT91SAM7S256
    23. Target interface: JTAG
    24. Target interface speed: auto
    25. Target endian: little
    26. Connecting to J-Link...
    27. J-Link is connected.
    28. Firmware: J-Link V9 compiled May 7 2021 16:26:12
    29. Hardware: V9.30
    30. S/N: 609300498
    31. Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    32. Checking target voltage...
    33. Target voltage: 3.09 V
    34. Listening on TCP/IP port 2159
    35. Connecting to target...
    36. J-Link found 1 JTAG device, Total IRLen = 4
    37. JTAG ID: 0x3F0F0F0F (ARM7)
    38. Connected to target
    39. Waiting for GDB connection...Connected to 127.0.0.1
    40. Executing script file [/home/vagrant/Documents/product/build/product/etc/gdb/reset.gdbinit] ...
    41. WARNING: Unsupported remote command "monitor sleep 500"
    42. WARNING: Unsupported remote command "monitor halt"
    43. WARNING: Unsupported remote command "load"
    44. WARNING: Unsupported remote command "set mem inaccessible-by-default off"
    45. WARNING: Unsupported remote command "monitor flash download = 1"
    46. WARNING: Unsupported remote command "monitor flash breakpoints = 1"
    47. WARNING: Unsupported remote command "tb main"
    48. WARNING: Unsupported remote command "monitor reset"
    49. Reading all registers
    50. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    51. Read 4 bytes @ address 0xFFFFFFFC (Data = 0x00000000)
    52. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    53. Read 4 bytes @ address 0xFFFFFFFC (Data = 0x00000000)
    54. Read 2 bytes @ address 0x00000000 (Data = 0x0000)
    55. Read 2 bytes @ address 0xFFFFFFFE (Data = 0x0000)
    56. Read 2 bytes @ address 0xFFFFFFFC (Data = 0x0000)
    57. Read 2 bytes @ address 0x00000000 (Data = 0x0000)
    58. Read 2 bytes @ address 0xFFFFFFFE (Data = 0x0000)
    59. Read 2 bytes @ address 0xFFFFFFFC (Data = 0x0000)
    60. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    61. Read 4 bytes @ address 0xFFFFFFFC (Data = 0x00000000)
    62. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    63. Read 4 bytes @ address 0xFFFFFFFC (Data = 0x00000000)
    64. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    65. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    66. Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    67. Downloading 112 bytes @ address 0x00101400 - Verified OK
    68. Downloading 15952 bytes @ address 0x00101600 - Verified OK
    69. Downloading 16016 bytes @ address 0x00105450 - Verified OK
    70. Downloading 15888 bytes @ address 0x001092E0 - Verified OK
    71. Downloading 16080 bytes @ address 0x0010D0F0 - Verified OK
    72. Downloading 16064 bytes @ address 0x00110FC0 - Verified OK
    73. Downloading 16096 bytes @ address 0x00114E80 - Verified OK
    74. Downloading 16048 bytes @ address 0x00118D60 - Verified OK
    75. Downloading 16032 bytes @ address 0x0011CC10 - Verified OK
    76. Downloading 16000 bytes @ address 0x00120AB0 - Verified OK
    77. Downloading 16032 bytes @ address 0x00124930 - Verified OK
    78. Downloading 16032 bytes @ address 0x001287D0 - Verified OK
    79. Downloading 2444 bytes @ address 0x0012C670 - Verified OK
    80. Downloading 7248 bytes @ address 0x0012CFFC - Verified OK
    81. Downloading 2 bytes @ address 0x0013FFFE - Verified OK
    82. Writing register (PC = 0x 101400)
    The gdb script in question is as follows:
    1. monitor sleep 500
    2. monitor halt
    3. load
    4. set mem inaccessible-by-default off
    5. monitor flash download = 1
    6. monitor flash breakpoints = 1
    7. tb main
    8. monitor reset
    I tried wrapping the commands in `eval "<line>"` to no avail. The `-x` flag yields the same result. How can I make JLinkGDBServer execute this gdb script upon connection? Thanks for your time.
  • The -xc option is for GDB not GDBServer.
    These are 2 different products from 2 different vendors.
    gdbinit files are for GDB, not GDBServer.
    I need to check why the "GDBInit file:" output for GDBServer actually exists because it does not really make any sense.
