[SOLVED] Change Expression value in script
  • [SOLVED] Change Expression value in script
    I want to change a global variable automatically after reset of the device.
    It is simple possible with the GUI (Watch windows -> Change value -> Enter). But how can I edit a expression in the jdebug script?
    Can anyone help me?
    If I understand correctly you are looking to populate the watch window automatically on each debug start, correct?
    How do you know beforehand what the expression name will be?
    The jdebug script is static.
    In any case what you could do is:
    Window.Clear ("Watched Data 1");
    Window.Add ("Watched Data 1", "test");
    etc.
