[SOLVED] Instruction Trace with J-Trace Pro Cortex M and Renesas RA6T1 in Ozone.
  • [SOLVED] Instruction Trace with J-Trace Pro Cortex M and Renesas RA6T1 in Ozone.
    currently I am examining the J-Trace Pro Cortex M Emulator (V3.0) on a Renesas RA6T1 CPU.
    I detail I am trying out the Instruction Trace Feature in the Tool Ozone (V3.24f)
    In the first column of the Instuction Trace Window the timestamps in cycles can be displayed. I am wondering if theses values are correct in every line.
    As example I have added following snapshot to the post.
    In the marked yellow line there is a LSLS instruction which should last two cycles according to trace. However in the Cortex M4 Reference Manual the LSL Instruction is named with 1 cycle.
    So is there a bug in the tool or do I have a misunderstanding here? Can anyone advise me?
    Thank you very much.
    We received your inquiry in parallel via our support system. As your probe is in valid support period we would keep further discussion in the support ticket.
    So this thread will be closed now to avoid duplicate or lost information.
