[SOLVED] Arm flasher ST STM32G070RB START
  • [SOLVED] Arm flasher ST STM32G070RB START
    We are using ST STM32G070RBT6 MCU in our production with Flasher ARM in our pcb tester. Flasher controlled via telnet service with #auto command. Config uploaded via J/flash.
    Our problem is the following:
    We start with BLANK MCU.
    probramming with #auto command get #OK without errors
    MCU DOESN'T start
    send #erase , get #OK no errors
    send #auto, get #OK without problem
    MCU DOESN'T start
    remove power
    connect the power again, MCU STARTS
    send #auto, get #OK and MCU starts
    so mcu doesnt start in case of blank MCU, just when reprogram MCU
    Start application checked in setup. and it is working when we are use j-flash...
    What is the problem?
    I can see that you also contacted us via the support ticket system.
    To keep the flow of information to one channel we will close this thread now.
