[ABANDONED] GDB closed TCP/IP connection when watching a variable
  • [ABANDONED] GDB closed TCP/IP connection when watching a variable
    I am working on Ubuntu 20.04 with Eclipse on a NXP LPC1830 chip. I am using a JLink Pro probe.
    I have noticed that when debugging and if I try to read 'this' in a C++ function, I am losing the connection to GDB and debugging stops.
    I have attached the JLink log file (middle removed else it was too big to be attached)
    And here is the JLink GDB server output (cut also in some place)
    Don't know what I can do more to investigate this issue...
    SEGGER J-Link GDB Server V7.52d GUI Version
    JLinkARM.dll V7.52d (DLL compiled Aug 17 2021 17:14:32)
    GDBInit file: none
    Terminal I/O port: 2333
    Generate logfile: off
    Verify download: off
    Init regs on start: off
    Silent mode: off
    Single run mode: off
    Target connection timeout: 5000 ms
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: LPC1830
    Target interface: SWD
    Target interface speed: 4000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link ARM-Pro V3.x compiled Jun 6 2014 16:00:09
    Hardware: V3.00
    S/N: 173001256
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 2.80 V
    Listening on TCP/IP port 2331
    Connecting to target...
    Connected to target
    Reading all registers
    Read 2 bytes @ address 0x2821BE0C (Data = 0xE8B0)
    Read 4 bytes @ address 0x2815F04C (Data = 0x4B04BD10)
    Reading 64 bytes @ address 0x2931A5C0
    Received monitor command: reset
    Resetting target
    Received monitor command: go
    Starting target CPU...
    Received monitor command: sleep 3000
    Sleep 3000ms
    Read 4 bytes @ address 0x2815F0C0 (Data = 0xF1B01A24)
    Read 4 bytes @ address 0x294FD810 (Data = 0x294FDC88)
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0x2821A510)
    Writing register (SP = 0x29fe7000)
    Read 4 bytes @ address 0x2821A510 (Data = 0x050BF101)
    Reading 64 bytes @ address 0x29FE7000
    Read 4 bytes @ address 0x00000000 (Data = 0x10018000)
    WARNING: Failed to read memory @ address 0xFFFFFFFC
    Read 2 bytes @ address 0x00000000 (Data = 0x8000)
    WARNING: Failed to read memory @ address 0xFFFFFFFE
    Resetting target
    Received monitor command: semihosting enable
    Semi-hosting enabled (Handle on BKPT)
    Received monitor command: semihosting IOClient 3
    Semihosting I/O set to TELNET and GDB Client
    Downloading 4 bytes @ address 0x40050018
    Read 4 bytes @ address 0x800001A4 (Data = 0xF8DFB672)
    Read 2 bytes @ address 0x800001A4 (Data = 0xB672)
    Received monitor command: SWO GetMaxSpeed 120000000
    Maximum supported SWO speed is 6000000 Hz.
    Received monitor command: SWO GetSpeedInfo
    Base frequency: 6000000Hz, MinDiv: 1
    Received monitor command: SWO Start 0 6000000
    SWO started.
    Received monitor command: SWO EnableTarget 120000000 6000000 1 0
    SWO enabled successfully.
    Read 4 bytes @ address 0x10400BB0 (Data = 0x0000E7FE)
    Read 2 bytes @ address 0x10400BB0 (Data = 0xE7FE)
    Downloading 16224 bytes @ address 0x28000000
    Downloading 9476 bytes @ address 0x28404370
    Writing register (PC = 0x28000180)
    Read 2 bytes @ address 0x2800DE34 (Data = 0xB510)
    Setting breakpoint @ address 0x2800DE34, Size = 2, BPHandle = 0x0001
    Read 2 bytes @ address 0x280DD30C (Data = 0x2401)
    Setting breakpoint @ address 0x280DD30C, Size = 2, BPHandle = 0x0002
    Read 2 bytes @ address 0x280DD490 (Data = 0xF1B8)
    Setting breakpoint @ address 0x280DD490, Size = 4, BPHandle = 0x0003
    Read 2 bytes @ address 0x280DD570 (Data = 0x4B14)
    Setting breakpoint @ address 0x280DD570, Size = 2, BPHandle = 0x0004
    ...Breakpoint reached @ address 0x2800DE34
    Removing breakpoint @ address 0x2800DE34, Size = 2
    Removing breakpoint @ address 0x280DD30C, Size = 2
    Removing breakpoint @ address 0x280DD490, Size = 4
    Removing breakpoint @ address 0x280DD570, Size = 2
    Read 4 bytes @ address 0x2800DE34 (Data = 0xB0D0B510)
    Read 1 bytes @ address 0x289EB424 (Data = 0x00)
    Setting breakpoint @ address 0x280DD30C, Size = 2, BPHandle = 0x0005
    Setting breakpoint @ address 0x280DD490, Size = 4, BPHandle = 0x0006
    Setting breakpoint @ address 0x280DD570, Size = 2, BPHandle = 0x0007
    ...Breakpoint reached @ address 0x280DD30C
    Read 4 bytes @ address 0x280DD30C (Data = 0xF04F2401)
    Read 4 bytes @ address 0x281AEE5C (Data = 0xB0B5B530)
    Reading 64 bytes @ address 0x2943B400
    WARNING: Failed to read memory @ address 0xAAAAAAAA
    Read 4 bytes @ address 0x28416190 (Data = 0x00000000)
    Read 4 bytes @ address 0x28273158 (Data = 0x00000000)
    GDB closed TCP/IP connection (Socket 16)
