[SOLVED] -Werror=format-truncation switching from SEGGER 3.34 to SEGGER 5.50
  • [SOLVED] -Werror=format-truncation switching from SEGGER 3.34 to SEGGER 5.50
    I am developing an application. I used SES version 3.34 to develop the project now I am trying to upgrade SES to version 5.50 and I have some compilation errors like this:
    • '%05d' directive output may be truncated writing between 5 and 7 bytes into a region of size 6 [-Werror=format-truncation=]
    that I never had in the 3.34 version.
    Is there a way to fix these compilation errors?
    thanks.
    Please note that Embedded Studio V3.34 is out of support and maintenance for many years now and the V5.xx releases are very different.
    A general migration guide from V4 to V5 can be found here:
    wiki.segger.com/Migrating_proj…_Embedded_Studio_V4_to_V5
    For V3 to V5 even more additional steps might be required. But as the difference between V3 and V5 is so large we recommend to create a new project with V5 and add the additional sources manually to your project as that is most likely the more effortless approach.
