I need a 3D graphic tool that plugs in or is built into the Segger IDE that allows me to debug trigonometric and geometry functions in 3D graphic space.
Needed Features:
I want to observe xyz cartesian coordinates converted to polar coordinates and back again, displayed within a 3D sphere.
I want to graphically observe an accelerometer's xyz motion vector displayed inside a sphere in real-time, while the firmware hardware is running.
I want to graphically observe a magnetometer's North pole vector displayed inside a sphere in real-time, while the firmware hardware is running.
I want to graphically observe an accelerometer's determined 1G gravitational vector inside a sphere in real-time.
I want to observe all of the above at the same time.
Observing such things allows a software developer to confirm the validity of the geometric functions.
The graphic tool works like this:
The project's C firmware source code invokes a graphic tool with a collection of coordinates as parameters, such as xyz coodinates, vector color, vector thickness, backdrop sphere, etc.
Then during a Segger IDE debug session, the following occurs...
A popup graphic window appears showing the graphic vectors and objects in 3D space, very similar to observing a small video game.
The graphic tool displays the coordinates as one or more vectors rotating around a sphere graphic object.
Each vector can be color controlled by the debugging software, whereby a software developer can readily confirm that various geometric functions are working correctly.
It seems to me that debugging software means more than a text trace in a console window. Debugging can also be visual in a 3D graphic space. It's a faster and more reliable approach to graphic and geometric functions.
Is there such a tool anywhere in the marketplace?
If not, I would like to see Segger or another 3rd party company build this tool. IT IS VERY MUCH NEEDED!
Ken Huebner
Software Developer
Needed Features:
Ken Huebner
Software Developer
