1. I'm using a LISTWHEEL widget, I've set the snap position(LISTWHEEL_SetSnapPosition), LISTWHEEL_MoveToPos, & LISTWHEEL_SetSel. Everything works fine in my simulation. When I try to use the on my demo board, I can see LISTWHEEL getting created, data getting attached to it but I couldn't get the desired output. Basically I tried to create 3 LISTWHEELs, & tried to updates each of them with day, month & year. I debugged by marking a breakpoint, it passes through it, but never gets updated.
2. When I use static const char*, if the two strings in the array are similar, it's causing some problem. As I've mentioned in the below example, foo1 gives me weird output, but foo2 gives me required output. Whys is it so?
Please help me with this. Thank you.
-- Rahul
-- Rahul
