[ABANDONED] Can not run the programm on my device using J-Link
  • [ABANDONED] Can not run the programm on my device using J-Link
    I am using nrf52832 and configuring the processor using JLink. I can say for sure that the connection to the device is established and even it is possible to download the program to it, but it (the program) does not start, although there are no errors/exceptions and, accordingly, the LEDs do not light up. What could be the problem? I have already read many forums and documentations, but I have not yet been able to find a solution. You are my last hope:)
    P. s. OS: Windows 10.
    If it is necessary to add more information about smth, I give it:)
    Could you provide the serial number of your J-Link?
    Are you using a custom board or eval board?
    Did you create the project from scratch or did you use some project generator?
    Should you be using the nRF52-DK Board you can use our embOS blinky sample that should run out of the box:
    segger.com/downloads/embos/emb…texM_EmbeddedStudio_Trial
    Simply download the embOS Trial and unzip it.
    You can find the project under Start\BoardSupport\NordicSemi\nRF52832_nRF52_DK
    Does that project work on your board as well?
