Hello nice to meet you all,
I have a J-Link edu mini, which works really well when I use it with official NXP's iMXRT1050-EVKB board.
So I made my custom board using iMXRT1050 IC and when I connect my J-Link to the board, it keeps on repeating initiation.
I have searched other forums, but the most similar problem was caused by low VTref(>3.3V).
I have seen case where the connection fails with "cannot connect to target" with InitTarget() start error.
But it seems that my case is sort of making connection, but not able to make the connection after few tries.
I'm using below pins to connect iMXRT1050 and I'm using short 10pin cable. The same setup doesn't have problem when using iMXRT1050 EVB.
![](https://forum.segger.com/index.php/Attachment/4735-10pin-PNG/?thumbnail=1&s=e04758287422257520e20040cdf5ab76cfd3e7e9)
