Context-Switch Time and every Task in a own File and
  • Context-Switch Time and every Task in a own File and
    Hallo,
    I am student and compare different RTOS for a Cortex-M3 (LPC1768 from NXP) and Keil compiler. At the moment I'm checking the Segger embOS.
    To measure the context-switch-time I used the scope example comes with the evalversion of the embOS. My results are 4,66 µs with 72 MHz Core-Clock and 3,2 µs with 100 MHz Core-Clock. If I calculate correctly, they are round 320 CPU-Cycles. Is this a realistic time? What was the Core-Clock by your test for Cortex-M3 shown here?
    Furthermore, I want every task placed in an own C-File. But it doesn’t work. I have made a header with the prototype of every task (like I do for any C-function). But if I link the project the Keil linker reports: "Undefined symbol "Taskname" (referred from main.o)" and that for every task. In the main.c file I use just the OS_CREATETASK() with the "symbol" of the Taskname. If I put all tasks together with the main function in one C-File it works fine.
    What's my mistake? Do you have an example with the tasks in different files?
    Greetings
    Martin
  • Hello Martin,
    yes, this is a realistic time. We measured with 60 MHz a context switch time of 5.1 usec.
    Your second question seems to be more a problem with C language and it is not related to embOS.
    I don't have a sample right now but it should not be a problem to support you with a sample where the task functions are in their own C files.
    Maybe you want to contact us directly, so I will be able to send you a Keil project.
    Til
  • Hello Til,
    you are right, just a blunder in C. I used the task routines from your example and they are all "static" defined. With static that can't work in another C-File.
    Thank you for Help and Information
    Martin
