[SOLVED] Systemview cjtag
  • [SOLVED] Systemview cjtag
    Hi!
    I am currently evaluating the use of Systemview for our purposes.
    We are using a cc1310 from TI with the cJtag as the debug interface.
    Our Jlink-Plus works flawlessly with it in Code Composer Studio for normal debugging purposes.
    My question is: It seems that Systemview is still missing the Existing Session option from the connect dialog (rtt viewer for example has it). See this thread from the past : Connect to existing debug session not available
    In the Target Recorder Configuration I can only Select Jtag, and no cJtag. This means that with our current design I would not be able to use Systemview to trace our tasks.
    Can you confirm this, or maybe there is a setting which I have overlooked?
    Thanks!
    cJTAG is currently not available for SystemView.
    We will add it to our feature wishlist but can't name a fixed timeschedule when it will be available.
