[SOLVED] Abnormal function of Linux JlinkConfigExe
  • [SOLVED] Abnormal function of Linux JlinkConfigExe
    It was successful to change the Jlink startup mode to CMSIS_DAP using JlinkConfigExe, but it was inoperable to change the Jlink startup mode of CMSIS_DAP mode to Jlink.
    In the Arch Linux environment.
    Linux archlinux 5.10.27-1-lts #1 SMP Tue, 30 Mar 2021 13:22:29 +0000 x86_64 GNU/Linux
    We need some add. information to be able to help here.
    1. What does "unsuccessful" mean? (J-Link not listed in configurator anymore once switched to CMSIS-DAP mode? Listed but re-configure throws an error? If there is an error message, can you send a screenshot?)
    2. Does it work under ArchLinux if JLinkConfigExe is started with superuser access rights?
    3. Does it work under Windows?
  • Right-click-> Configure.
    No configuration dialog box is displayed.
    There is no error message.
    But using JLinkConfigExe in linux.
    Can display the configuration dialog box correctly.
    CMSISM-DAP mode can be selected normally, but Jink mode cannot be selected.
    But using sudo JLinkConfigExe in linux.
    Can choose Jlink mode to start normally
    Windows right-click-> Configure.
    The post was edited 1 time, last by taotieren ().
    The test found that the udev rules of cmsis-dap need to be configured. After configuration, the jlink and CMSIS-DAP modes can be switched normally through JlinkConfigExe.
    Shell-Script: 99-cmsis-dap.rules
    1. sudo cat > /etc/udev/rule.d/99-cmsis-dap.rules << EOF
    2. # Copy this file to /etc/udev/rules.d/
    3. # If rules fail to reload automatically, you can refresh udev rules
    4. # with the command "udevadm control --reload"
    5. # This rules are based on the udev rules from the OpenOCD project, with unsupported probes removed.
    6. # See http://openocd.org/ for more details.
    7. #
    8. # This file is available under the GNU General Public License v2.0
    9. ACTION!="add|change", GOTO="cmsis_dap_rules_end"
    10. SUBSYSTEM=="gpio", MODE="0660", GROUP="plugdev", TAG+="uaccess"
    11. SUBSYSTEM!="usb|tty|hidraw", GOTO="cmsis_dap_rules_end"
    12. # CMSIS-DAP compatible adapters
    13. ATTRS{product}=="*CMSIS-DAP*", MODE="666", GROUP="plugdev", TAG+="uaccess"
    14. LABEL="cmsis_dap_rules_end"
    15. EOF
  • That’s why I asked for additional info....
    I already suspected that it is the rules file but now we know it.
    We will fix this in one of the next versions.
