JLink stopped connecting to Freescale Kinetis K60
  • JLink stopped connecting to Freescale Kinetis K60
    My system:
    I've a JLink ARM version 8.0 with
    I'm testing it with the JLink command line 4.25a (which is a beta but I've also tested with the 4.24b).
    I've it connected to a Freescale evaluation board TWR-K60N512 which has a Freescape CPU Kinetis MK60N512VMD100
    Unfortunately as everything was going well I wasn't recoding everything I was doing, but I can send you any log now.
    The last working thing I was doing:
    I clicked in the JLink command line icon.
    I just entered the command:
    exec device = MK60N512VMD100
    Then I entered the command:
    loadbin image.bin 0
    And everything worked properly, because the following command was able to show me the
    data that was saved in the flash.
    mem 0 10
    Then I just tried to reset the board:
    r
    After the image was saved, then everything started going wrong:
    Executing the JLink shows this:
    C:\Archivos de programa\SEGGER\JLinkARM_V425a>JLink.exe
    SEGGER J-Link Commander V4.25a ('?' for help)
    Compiled Mar 2 2011 12:24:56
    DLL version V4.25a, compiled Mar 2 2011 12:24:38
    Firmware: J-Link ARM V8 compiled Jan 31 2011 18:34:52
    Hardware: V8.00
    S/N: 158000570
    OEM: IAR
    VTarget = 3.313V
    Info: ARM AP[0]: 0x24770011, AHB-AP
    Info: ARM AP[1]: 0x001C0000, JTAG-AP
    ****** Error: No APB-AP found.
    No devices found on JTAG chain. Trying to find device on SWD.
    Info: Found SWD-DP with ID 0x2BA01477
    WARNING: ROM table: Two components occupy the same memory space.
    Info: FPUnit: 1 code (BP) slots and 0 literal slots
    WARNING: CPU core not found.
    No device found on SWD.
    Did not find any core.
    If I try to reset the device to start from the first instruction, everything fails in the same way:
    J-Link>r
    Reset delay: 0 ms
    Reset type NORMAL: Toggle reset pin and halt CPU core.
    WARNING: CPU not halted after Reset, halting using Halt request
    I've seen in the forums that some related problems are solved with unlock, but unlocking and reset gives me:
    J-Link>unlock Kinetis
    Unlocking device...O.K.
    J-Link>r
    Reset delay: 0 ms
    Info: Could not measure total IR len. TDO is constant high.
    ****** Error: JTAG Id mismatch. Expected: 0x0BA00000, found: 0x00000000)
    During this operation a dialog appears saying that "TCK (pin 9) low, but should be high. please check target hardware".
    I can do any operation any longer because it always fails with similar messages about things that I don't understand: SWD-DP, APB-AB, ROM tables...
    Is it possible for me to do any operation to fix this situation. How can I mass-erase the device, or stop it after a reset?
    Thank you very much in advance.
    usually the "unlock" command should mass-erase the device.
    Would it be possible to get the bin file you loaded into the internal flash of the MK60N ?
    We would like to reproduce and fix this.
  • I've seen what was the problem. The Kinetis K60 has some configuration registers from 0x400 to 0x40C.
    This means that it had some random values so the Kinetis was secured in a random way.
    After testing a lot of methods, the only way I was able to mass-erase the device was using the CodeWarrior with
    the OpenJTAG included in the board. Then I fixed my program and loaded the new program and
    everything worked properly.
    Definitely the "unlock Kinetis" command didn't mass-erase the device, even if no error happened in the process.
    The most confusing part was the error messages were not very clear about the device being secured.
    I don't know if it is technically possible to know if the device is secured and give a bit more friendly messages.
    I attached the wrong image that made me impossible to mass-erase the device with JLink.
    • image.zip
      (9.37 kB, downloaded 1,324 times, last: )
