[SOLVED]J-Link GDB Server - Connection closed!
  • [SOLVED]J-Link GDB Server - Connection closed!
    I'm having trouble with the J-Link GDB Server. The problem is that the connection to the GDB client closes immediately after the connection is established with the server.
    I'm running J-Link GDB Server on a Windows 7 64-bit PC. I have a SAM-ICE (J-Link ARM) v8.00, connected via JTAG to our board that has an AT91SAM9G10. The J-Link is using firmware "J-Link ARM V8 compiled Jan 31 2011 18:34:52". The GDB client version is 7.0.1.
    J-Link GDB Server V4.24b Log Window:
    SEGGER J-Link GDB Server V4.24b
    JLinkARM.dll V4.24b (DLL compiled Feb 22 2011 20:47:17)
    Listening on TCP/IP port 2331
    J-Link connected
    Firmware: J-Link ARM V8 compiled Jan 31 2011 18:34:52
    Hardware: V8.00
    S/N: 28004705
    OEM: SAM-ICE
    Feature(s): RDI
    J-Link found 1 JTAG device, Total IRLen = 4
    JTAG ID: 0x0792603F (ARM9)
    SAM-ICE found !
    Connected to 10.128.0.248
    SAM-ICE found !
    Connection closed!
    GDB client console output:
    target remote 10.128.1.92:2331
    Ignoring packet error, continuing...
    warning: unrecognized item "timeout" in "qSupported" response
    I actually had everything working when I was evaluating GDB Server about two weeks ago. At this time I was using GDB Server v4.20h and the firmware of the J-Link was an older revision. My settings on the client side haven't changed since then, but now it doesn't work. I'm wondering if updating J-Link's firmware caused the problem.
    I've also tried different combinations of GDB Server and ARM toolchains without success:
    Our Timesys toolchain (gcc v4.4.3, gdb v7.0.1).
    yagarto-bu-2.21_gcc-4.5.2-c-c++_nl-1.19.0_gdb-7.2_eabi_20101223 (connected to j-link gdb-server locally)
    yagarto-bu-2.20.1_gcc-4.5.1-c-c++_nl-1.18.0_gdb-7.1_eabi_20100813
    GDB Server 4.20h
    GDB Server 4.22f
    GDB Server 4.24b
    According to the following thread, arm-none-eabi-gdb.exe and j-link gdb-server 4.22f is working:
    JLinkGDBServer and gdb (arm-none-eabi-gdb): Remote 'g' packet reply is too long:
    But not for me.
    I've also tried different JTAG speeds without success.
    Suggestions are greatly appreciated! Thanks!
  • unrecognized item "timeout" in "qSupported" response
    similar thing here, but on Win XP, with GDB Server V4.24c :
    GNU gdb (Red Suite 2010Q1 by Code Red) 7.0.50.20100218-cvs
    This GDB was configured as "--host=i686-mingw32 --target=arm-none-eabi".
    Reading symbols from ... done.
    .gdbinit:7: Error in sourced command file:
    Malformed response to offset query, timeout
    This happens always when I try to connect for the second time.
    The first time after (re-)starting GDB Server it always works.
    Any idea?
    Gerald KK
  • Hi Gerald,
    we have fixed a problem regarding GDB Server + Starting and closing the debug session multiple times.
    We will release a new version of the software, later today (V4.24d, V4.25c).
    We will inform you as soon as the new version is available.
