[SOLVED] How to download latest jlink-arm software with 32bir arm core support?
  • [SOLVED] How to download latest jlink-arm software with 32bir arm core support?
    Dear All,
    I wanna use RPi-Zero-W with Jlink as standalone programmer.
    I have discovered that 32bit arm core support is dropped from V6.82g release.
    And so could you please help me to download latest jlink arm toolchain supporting 32bit arm cores?
    Thanks.
    I am not quite sure if I understood you correctly.
    Are you referring to the J-Link Software Pack?
    The J-Link Software and Documentation Pack is still available for ARM / Raspberry Pi here:
    segger.com/downloads/jlink/#J-…twareAndDocumentationPack
    Screenshot:
    Fabian Federschmidt
  • Thanks for your quick reply.
    Because of RPi-Zero-W board has arm 32bit arm mcu on it, JlinkExe(from Jlink sotware pack v.698a) is crashing with SegFault on latest Raspberrypi-OS.
    I am trying to run "Jlink Software Pack" from newest to oldest on RPi-Zero-W.
    I have tried from v6.98a to 6.94 but SegFault problem is still exist.
    From this thread i learned that 32bit support is dropped from a specific version of "Jlink software Pack".
    [SOLVED] SegFault / Illegal Instruction starting with Flasher V6.84 on RaspberryPi B+ (ARMv6)
    could you tell me what is the latest release supports 32bit arm cores without segfault error?
    Thanks.
  • Additionally, all versions of JLink Software Pack are working on RaspBeryPi Model 3+ without any error.
    Same software, same operation system (raspbery OS) only hw is different.
    Could you please help me how work on RPi-Zero-W ?
    Thanks.
    It is not a matter of 32-bit and 64-bit.
    As Fabian wrote, we DO HAVE a 32-bit ARM version.
    The problem is more the architecture.
    Almost all Raspberry Pi derivatives and their alternatives (Orange Pi, Odroid, NVIDIA Jetson, ...) are either ARMv7-A (Cortex-A8, A9, ...) or ARMv8-A (Cortex-A53, A72, ...) based.
    While v7-A is always 32-bit, v8-A supports 64-bit and a 32-bit mode which is compatible to v7-A.
    The Linux ARM 32-bit version of J-Link is compiled for v7-A. The 64-bit version for v8-A.
    The Raspberry Pi Zero-W is one of the very rare remaining ARMv6 based Linux ARM systems in the world.
    Long story short:
    ARMv6 based systems are not supported by current versions. v7-A is minimum.
    There are no plans to change this as ARMv6 is legacy and almost not present anymore (If I remember correctly, the last standard Raspberry that was v6 was the Raspberry Pi 1 and they are at Raspberry Pi 4B now)
