[SOLVED] Has the J-Link Plus an internal series resistor on the RESET pin?
  • [SOLVED] Has the J-Link Plus an internal series resistor on the RESET pin?
    Hi
    I would like to know if the reset pin (Pinout for SWD: Pin 15) of the J-Link Plus has an internal series resistor?
    We must ensure that the J-Link Plus is short circuit proof for the case when the reset pin (of the chip that is currently debugged) is accidentally driven by another chip in the system.
    the reset pin of J-Link is open drain.
    J-Link only drives it LOW in case it is activated. To generate a HIGH level, it releases the pin and let a pull-up do the work.
    So this is short-circuit proof.
