[SOLVED] GDB Waiting for connection ...
  • [SOLVED] GDB Waiting for connection ...
    I'm debugging custom hardware that has a ST32GM431C8 MCU and am connected using a J-Link. My connection to the hardware is the 5-wire JTAG. When running using Keil MDK5 I have a problem in which the Keil debug windows work fine until I execute a specific version of code then the windows get trashed and I cannot debug. I was hoping to try the GDB debugger with J-Link (I'm new to GDB). When I launch either the command line program or the GUI version I get "GDB waiting for connection..."
    I was hoping that I could use the GDB command line version with J-Link to debug to see if my problem was related to the Keil environment or if I have another problem. Here is what get's displayed by GDB:
    1. Verify download: off
    2. Init regs on start: off
    3. Silent mode: off
    4. Single run mode: off
    5. Target connection timeout: 0 ms
    6. ------J-Link related settings------
    7. J-Link Host interface: USB
    8. J-Link script: none
    9. J-Link settings file: none
    10. ------Target related settings------
    11. Target device: Unspecified
    12. Target interface: JTAG
    13. Target interface speed: 4000kHz
    14. Target endian: little
    15. Connecting to J-Link...
    16. J-Link is connected.
    17. Firmware: J-Link EDU Mini V1 compiled Feb 18 2021 11:25:23
    18. Hardware: V1.00
    19. S/N: 801020066
    20. Feature(s): FlashBP, GDB
    21. Checking target voltage...
    22. Target voltage: 3.30 V
    23. Listening on TCP/IP port 2331
    24. Connecting to target...
    25. J-Link found 2 JTAG devices, Total IRLen = 9
    26. JTAG ID: 0x4BA00477 (Cortex-M4)
    27. Connected to target
    28. Waiting for GDB connection...
    Thanks --
  • What you have sent is not the output of GDB but GDBServer.
    GDB: GNU debugger. 3rd party command line debugger.
    GDB remote protocol: Generic protocol used by GDB to communicate with a GDBServer.
    GDBServer: Translates from GBD remote protocol to vendor specific ApI pf debug probe.
    Just starting GDBServer does not get you anywhere. You also need a GDB setup.
  • Is there a Windows version of GDB? I see MinGW is quite old. If what is needed is a setup with GDB and GDB Server I am prepared to do that I'll just need help pointing in the right direction. I looked at GDB from GNU but if I don't have to generate the whole build environment for GNU I'd prefer the easier path.
  • Google: “arm gcc toolchain”
    and you will end up here:
    developer.arm.com/tools-and-so…ools/gnu-toolchain/gnu-rm
    Comes with everything:
    gcc, g++, gdb, ...
