I am using a NXP board containing a Cortex-M33 but i am not able to erase, reset or program the board.
when trying to connect i get the following:
J-Link>connect
Device "CORTEX-M33" selected.
Connecting to target via SWD
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00C0000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: implemented
Secure debug: disabled
CoreSight components:
ROMTbl[0] @ E00C0000
ROMTbl[0][5]: C0181000, CID: 00000000, PID: 00000000 ???
ROMTbl[0][6]: C0182000, CID: 00000000, PID: 00000000 ???
ROMTbl[0][7]: C0183000, CID: 00000000, PID: 00000000 ???
ROMTbl[0][8]: C0184000, CID: 00000000, PID: 00000000 ???
ROMTbl[0][9]: C0185000, CID: 00000000, PID: 00000000 ???
ROMTbl[0][10]: C01BF000, CID: 00000000, PID: 00000000 ???
Cortex-M33 identified.
When I try to reset:
J-Link>r
Reset delay: 0 ms
Reset: Core did not halt after reset, trying to disable WDT.
Reset: CPU did not halt after reset.
Reset: Using fallback: Reset pin.
Reset: Reset device via reset pin
Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
Reset: Reconnecting and manually halting CPU.
DPIDR: 0x6BA02477
AP[0]: Core found
CPU could not be halted
DPIDR: 0x6BA02477
AP[0]: Core found
Reset: Failed. Toggling reset pin and trying reset strategy again.
SWD speed too high. Reduced from 4000 kHz to 2700 kHz for stability
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
****** Error: Failed to halt CPU.
What could be causing this behaviour? Any help would be appreciated.
J-Link>connect
DPIDR: 0x6BA02477
AP[0]: Core found
J-Link>r
Reset delay: 0 ms
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
DPIDR: 0x6BA02477
AP[0]: Core found
