when i called "GUI_ExecDialogBox"before , GUI_StroreKeyMsg will create a WM_KEY in WM_CALLBACK???why?
GUI_StoreKeyMsg() adds WM_KEY messages to a buffer. Without any windows, the buffered messages cannot be sent anywhere.
As soon as you create the dialog and GUI_Exec() is called (GUI_ExecDialogBox() calls GUI_Exec()), the stored key message gets sent to the window that has input focus which is the dialog window.
FlorianPlease read the forum rules before posting.
Or you can contact us via e-mail. -
but i don't want to go to the WM_KEY in _cbCallback when i called GUI_ExecDialogBox() at first, how can i avoid ? because GUI_StoreKeyMsg() or GUI_SendKeyMsg() i used to Physical keys, The dialog box will pop up and disappear right away, thank u for your solution
The post was edited 1 time, last by xiongda ().
If the dialog window has the focus, you will always land in WM_KEY, when a key message has been stored. So to avoid landing in WM_KEY, no key message should be stored. If there's no other way, you can add a guard to the WM_KEY case to control when the key is handled.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
Tags
