[SOLVED]Debugger in uVision3 V4.00a can not load AXF file
  • [SOLVED]Debugger in uVision3 V4.00a can not load AXF file
    Recently I bought SEGGER J-link JTAG.
    Today I installed it on my computer.
    Flash download and communication in Keil works fine, but when I try to debug I got this message:
    Error: Could not load file 'xxx.AXF'
    Debugger aborted !
    ps.
    I found this similar post [url=http://www.keil.com/forum/12732/,]http://www.keil.com/forum/12732/,[/url]
    where a guy is explaining the same problem, only he is using EK-LM3S8962 evaluation board.
    I downloaded file that had helped him ("TLM.dll"), but it was no help to me.
    KEIL INFO:
    Tool Version Numbers:
    Toolchain: RealView MDK-ARM Version: 4.01
    Toolchain Path: BIN40\
    C Compiler: Armcc.Exe V4.0.0.524 [Evaluation]
    Assembler: Armasm.Exe V4.0.0.524 [Evaluation]
    Linker/Locator: ArmLink.Exe V4.0.0.524 [Evaluation]
    Librarian: ArmAr.Exe V4.0.0.524 [Evaluation]
    Hex Converter: FromElf.Exe V4.0.0.524 [Evaluation]
    CPU DLL: SARMCM3.DLL V4.01
    Dialog DLL: DARMP1.DLL V1.11a
    Target DLL: Segger\JL2CM3.dll V1.05g
    Dialog DLL: TARMP1.DLL V1.11a
