This bug is somewhat related to Ozone window views geometry lost when dragging window to another screen - Ozone related - SEGGER - Forum
I just updated to V3.22a. When restoring the window from maximised (either by pressing the button or dragging the title bar), sometimes Ozone will forget its previous size and become a minimum size:
Reproduction steps (I can make this happen 100% of the time):
FYI, I have a three-monitor setup and the main monitor (on which I use Ozone) is scaled to 125%, while the others are scaled to 100%. Using the steps above, I can also reproduce the issue on a laptop with 200% scaling on a single monitor. I'm not sure if the bug has anything to do with display scaling, however.
SECONDARY BUG:
When this happens, the sizes of the panels in Ozone are also decreased (if they are large enough to start with)! This was supposedly fixed already.
I can make a video demonstrating both of these bugs, if necessary.
- Open Ozone
- Close the "welcome to Ozone" box
- Restore the window and resize it to a reasonable size
- Close Ozone (this should save the window size)
- Open Ozone
- Maximise the window
- Close Ozone
- Open Ozone (window should be maximised)
- Click "open recent project" (make sure this option is available)
- Close Ozone
- Bug occurs: Window is placed in the top left corner of my screen and is at its minimum size
SECONDARY BUG:
