[SOLVED] Failed to write memory
  • [SOLVED] Failed to write memory
    I'm working on a custom board with NRF52805.
    I have no problem when downloading flash from C segger project.
    Connecting ‘J-Link’ using ‘USB’
    Connecting to target using SWD
    Loaded C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.20a/bin/JLink_x64.dll
    Firmware Version: J-Link V11 compiled Nov 12 2020 10:07:08
    DLL Version: 6.88a
    Hardware Version: V11.00
    Target Voltage: 3.322
    Device "NRF52805_XXAA" selected.
    InitTarget() start
    InitTarget() end
    DPIDR: 0x2BA01477
    AP[2]: Stopped AP scan as end of AP map has been reached
    AP[1]: JTAG-AP (IDR: 0x02880000)
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
    Loading target script file nRF_Target.js
    Preparing target for download
    Executing Reset script Reset();
    Downloading ‘Executable_1.elf’ to J-Link
    Programming 3.2 KB of addresses 00000000 — 00000d29
    J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match
    Download successful
    When I try to download nordic project (zephyr) there are "Failed to write memory" errors from jlink.
    Loaded C:/Users/rpier/ncs/v1.4.99-dev1/toolchain/segger_embedded_studio/bin/JLink_x64.dll
    DLL Version: 6.88b
    Target Voltage: 3.325
    Device "CORTEX-M4" selected.
    DPIDR: 0x2BA01477
    AP[0]: Core found
    Executing Reset script TargetInterface.resetAndStop()
    Downloading ‘zephyr.elf’ to J-Link
    Programming 80.6 KB of addresses 00000000 — 0001428f
    Download failed
    Failed to write memory.
    Programming 1.1 KB of addresses 00014290 — 0001474b
    There is no such issue known to us.
    I can see that the Nordic Zephyr project is not setup correctly.
    SEGGER Project:
    Zephyr:
    Could you select the device "NRF52805_XXAA" for the Zephyr project and try again?
