[ABANDONED] Use SystemView v3.20 and Ozone v3.20c simultaneously
  • [ABANDONED] Use SystemView v3.20 and Ozone v3.20c simultaneously
    I'm trying to use both SystemView and Ozone to debug my application.
    As per this thread: [SOLVED] Use SystemView 3 alongside Ozone?
    I've disabled RTT in Ozone, but SystemView still does not work while Ozone is active.
    This is what happens:
    • I can use SystemView when Ozone is not in active debug session
    • When I set up SystemView to record while Ozone has loaded and halted the program, as soon as I start the program, SystemView stops recording and shows empty trace
    • I have disabled RTT in Ozone by
    1. OnProjectLoad() : Project.SetRTT(0);
    and also tried the same thing manually.
    Could you give the latest Ozone version a try? Does it work then?
