regarding the Set Y-Axis Range ... dialog I have two proposals:
1) make the Enter key always accept the dialog. For some reason I always type a number and when I am finished press Enter and then wonder why the dialog is still there. Not sure if I am the only one but the extra Tab key hit (or two if only the first number is adjusted) could be saved there.
2) Set the currently set range as default and not the currently suggested best fit. If someone wants the latter, they can just use the available menu action for that. If I set a range and then want to adjust it a little bit, I always have to type it in completely instead of just adjusting what I want changed.
Just my thoughts.
Cheers
Just my thoughts.
Cheers
