[SOLVED] SWO usage
  • [SOLVED] SWO usage
    I am using Ozone connected with a Nordic nRF52840 based target via Segger JLink Plus (using the SWD interface). The trace pins currently are available, but not used because I don't have a JTrace adapter. We are now discussing about a new hardware revision which might exclude the use of SWO because the pin is needed for another peripheral chip (spi flash).
    My question is: will loosing the SWO pin restrict my debug possibilities? As far as I know, all communication between JLink and target is done via SWD and none using the SWO. I included the Segger RTT library from the Nordic SDK5, but from my understanding, this also comunicates via SWD.
    Dirk
    It will of course prevent your from using SWO, which is technically a restriction of your debug possibilities.
    The SWO pin is solely used for transmitting SWO data (ITM + ITM_printf()).
    If you are not using SWO anyway, it will not affect your debug setup.
  • Thank you Fabian!
    Hm, I hope. I simply want to ensure I don't overlook something. Maybe I should have stated the question this way: "If I cannot use ITM, do I loose functionality in Ozone?"
    in short yes.
    But if you are going for pin tracing anyhow you will get many advanced debug features that make any feature the ITM would bring obsolete.
    If you planned on using SWO for printf we recommend using RTT instead. Then also the SWO pin is not needed:
    segger.com/products/debug-prob…about-real-time-transfer/
    So effectively you do not loose any debug functionality.
