[SOLVED] JLink script to set RTC in K60
  • [SOLVED] JLink script to set RTC in K60
    Hi
    I'm a newcomer to the capabilities of Jlink, and am investigating the possibility of using Jlink (and/or associated utilities) to set the RTC within an NXP K60. On the surface of it, I think it ought to be possible using a (dynamically created/executed) Jlink script, but I'd appreciate a sanity check on this approach before I waste too much time on a possibly flawed approach.
    I am seeing some unexpected behaviour when attempting to read the related address ranges using commander (see attached) which may be indicative of my not having configured the device suitably beforehand, but again, any guidance would be most appreciated.
    David
    Can you sent the excerpt from the K60 manual you are following to achieve what you are trying to do?
  • Hi Alex
    Thank you for your response- I've figured out what I was doing wrong-which was that the perhiperal registers are only accessible once the corresponding SIM has its clock enabled- Like I said, I'm something of a a noob. Anyway, the extract below is a *.jlink file I generate dynamically and pass to jlink.exe, seems to be working fine...!
    r // Reset device
    w4 0x4004803C, 0x20000000 // SIM_SCGC6, RTC clock enable
    w4 0x4003D010, 0x00000001 // RTC_CR[SWR], assert software reset
    w4 0x4003D010, 0x00000000 // RTC_CR[SWR], take out of software reset
    w4 0x4003D010, 0x00000304 // RTC_CR, enable 32Khz clock, etc.
    w4 0x4003D000, 0X5F732C8B // RTC_TSR, Set (unix) time
    w4 0x4003D014, 0x00000010 // RTC_SR, Enable counter
    q // Exit JLink
    Thanks again
    David
  • Hi David,
    You have to start somewhere. :)
