[SOLVED] Linux: V3.20e, text in status bar flickering
  • [SOLVED] Linux: V3.20e, text in status bar flickering
    the status bar text regarding data tracing is flickering all the time (kinda pulsing being static on and static off sometimes and flickering in between).
    See attached video. ... Or not. Videos cannot be uploaded.
    This worked fine in V3.20d.
    Cheers
    The post was edited 1 time, last by icwiener ().
    Could you provide a video or gif showing the behaviour?
    What Linux version are you using exactly?
    We tried to reproduce the behaviour but with the little information we have we could not see the behaviour.
    Could you provide more information about your setup?
    What Linux are you using?
    Do you see the same behaviour in the latest Ozone version V3.20i?
    Could you provide an example project for reproduction that would run on an eval board that shows this behaviour?
    I am on Arch Linux with Ozone 3.20i and still see the problem.
    I am running a minimal example project on a Nucleo board with reflashed debugger.
    Steps to reproduce for me:
    - start Ozone and load project
    - load start debugging
    - click in the Data Sampling view
    Now the sampling counter is shown in status bar and flickers. The flickering is not always there but quite often.
    It is the same project that I sent you (Nino) on September 20th via email. The zip archive (hydrotherm.zip) contains a simple makefile project and a jdebug file. Do you still have that?
    Cheers
    The post was edited 2 times, last by icwiener ().
    Please note that Ozone is officially only supported on Ubuntu.
    Do you see the same behaviour there?
    Please understand due to the vast number of different Linux distributions and every one of them doing something slightly different it is near impossible to provide support for all of them, even if it is "just the major ones".
    For us everything worked correctly on Ubuntu. If you can provide a reproducer for Ubuntu we will gladly take another look.
    I totally understand that you cannot support every single Linux distro. I will try this on Debian over the week end. This is the closest I can get to Ubuntu.
    Cheers
