J-Flash error
  • J-Flash error
    Hi I am trying to use J-Flash with an AT91SAM7S256 via USB/JLink.
    Trying to use the command "Read Back", from a connected device causes the error listed below.
    This error is apparent with version V379z02, V378d, but version V374m works OK.
    Edit: v374m works if initial JTAG speed is 10KHz, the other versions do not. this was the main project difference between the versions that I noticed.
    - 1024 sectors, 1 range, 0x100000 - 0x13FFFF
    - ERROR: Write memory error @ address 0x00200000, word access: Memory access timeout.
    Failed to verify RAMCode for CPU clock frequency detection!
    - ERROR: RAM check failed @ address 0x00200000.
    - ERROR: Write: 0xE7FEE7FD E07CE062
    - ERROR: Read: 0xAAAAAAAA AAAAAAAA
    - ERROR: (0 bytes of RAM have been checked successfully)
    - ERROR: Failed to read back target memory
    Disconnecting ...
    - Disconnected
    The post was edited 1 time, last by simonb ().
  • Hello simonb,
    unfortunately we can not reproduce the problem.
    We have tested the latest beta version (V379z02)
    and the latest release version (V378d) without any problems.
    Hardware for testing:
    Atmel AT91SAM7S256-EK
    Olimex SAM7P256
    The following information may be useful in order to find the source of the problem:
    1) Do you use an eval board or a custom hardware?
    2) Which J-Link hardware version do you use?
    3) Could you please set the J-Flash log level to "All messages" and post the complete J-Flash log output?
    The log level can be changed at Options->Global Settings->General log level
    If you use a custom hardware the PLL settings could be the problem.
  • Hi Alex.
    This is our own custom hardware.
    The J-Link device is the Atmel badged one, SAM-ICE hw v5.2
    I have cut and pasted the log data below, (the website upload function does not support .txt or .log files.
    Best Regards,
    SimonB.
    T05CC 566:606 SEGGER J-Link ARM DLL Log File (0000ms, 0000ms total)
    T05CC 566:606 Logging started @ 2008-03-03 08:16 (0000ms, 0000ms total)
    T05CC 566:606 DLL Compiled: Feb 25 2008 12:39:11 (0000ms, 0000ms total)
    T05CC 583:692 ***** Logging restarted ??? ***** (0000ms, 0000ms total)
    T05CC 583:692 JLINKARM_SelectUSB(Port = 0) returns 0x00 (0000ms, 0000ms total)
    T05CC 583:693 JLINKARM_OpenEx(...)Firmware: J-Link compiled Dec 03 2007 17:15:31 ARM Rev.5 (0005ms, 0005ms total)
    T05CC 583:706 returns O.K. (0000ms, 0005ms total)
    T05CC 583:706 JLINKARM_TIF_Select(JLINKARM_TIF_JTAG) returns 0x00 (0000ms, 0005ms total)
    T05CC 583:708 JLINKARM_ConfigJTAG(IRPre = 0, DRPre = 0) (0000ms, 0005ms total)
    T05CC 583:708 JLINKARM_SetEndian(ARM_ENDIAN_LITTLE) returns 0x00 (0000ms, 0005ms total)
    T05CC 583:708 JLINKARM_GetFirmwareString(...) (0000ms, 0005ms total)
    T05CC 583:708 JLINKARM_SetSpeed(10) (0001ms, 0006ms total)
    T05CC 583:709 JLINKARM_GetSpeed() returns 0x0A (0002ms, 0008ms total)
    T05CC 583:711 JLINKARM_SetResetType(JLINKARM_RESET_TYPE_NORMAL) returns JLINKARM_RESET_TYPE_NORMAL (0000ms, 0008ms total)
    T05CC 583:711 JLINKARM_SetResetDelay(0) (0000ms, 0008ms total)
    T05CC 583:711 JLINKARM_ResetPullsRESET(ON) (0000ms, 0008ms total)
    T05CC 583:711 JLINKARM_Reset() >0x48 JTAG> >0x1B8 JTAG>TotalIRLen = 4, IRPrint = 0x01 (0050ms, 0058ms total)
    T05CC 583:761 >0x30 JTAG> >0x110 JTAG> >0x58 JTAG>_ResetBP0: >0x58 JTAG> >0x18 JTAG> >0x50 JTAG> >0x48 JTAG> >0x138 JTAG> >0x48 JTAG> >0x48 JTAG> >0x6F8 JTAG> >0x98 JTAG> >0x18 JTAG> >0x50 JTAG> (0376ms, 0434ms total)
    T05CC 584:137 JLINKARM_SetMaxSpeed() -- Detecting speed: - RTCK seems to be bridged with TCKRTCK seems to be bridged with TCK - 12kHz: >0x70 JTAG> O.K. - 50kHz: >0x68 JTAG> O.K. - 200kHz: >0x68 JTAG> O.K. - 600kHz: >0x68 JTAG> O.K. - 1600kHz: >0x68 JTAG> O.K. - 4800kHz: >0x68 JTAG> O.K. - 12000kHz: >0x68 JTAG> O.K. -- Auto JTAG speed: 8000 kHzAuto JTAG speed: 8000 kHz >0x08 JTAG> (0047ms, 0481ms total)
    T05CC 584:184 JLINKARM_GetSpeed() returns 0x1F40 (0000ms, 0481ms total)
    T05CC 584:184 JLINKARM_MeasureCPUSpeed(RAMAddr = 0x00200000) >0x48 JTAG> - Writing 0x08 bytes @ 0x00200000 -- WriteRemote(8 bytes @ 0x00200000) -- ReadRemote(8 bytes @ 0x00200000) >0x90 JTAG> >0x20 JTAG> >0x450 JTAG> >0x48 JTAG> >0x498 JTAG> >0x60 JTAG> >0x648 JTAG> >0x48 JTAG> >0x498 JTAG> -- ClockFreq: 32000 Hz returns 0x7D00 (0032ms, 0513ms total)
    T05CC 584:216 JLINKARM_GetDeviceFamily() returns 7 (0000ms, 0513ms total)
    T05CC 584:216 JLINKARM_GetIdData(...) ScanLen=4 NumDevices=1 aId[0]=1057951503 aIrRead[0]=0 aScanLen[0]=4 aScanRead[0]=0 (0000ms, 0513ms total)
    T05CC 584:216 JLINKARM_JTAG_GetDeviceID(DeviceIndex = -1) returns 0x3F0F0F0F (0000ms, 0513ms total)
    T05CC 584:216 JLINKARM_GetSpeed() returns 0x1F40 (0000ms, 0513ms total)
    T0D90 584:219 JLINKARM_ReadMemU32(0xFFFFFC30, 0x0001 Items, ...) -- ReadRemote(4 bytes @ 0xFFFFFC30) >0x50 JTAG> -- Data: 00 00 00 00 returns 0x01 (0005ms, 0518ms total)
    T0D90 584:224 JLINKARM_WriteU32(0xFFFFFC20, 0x0000FF01) - Writing 0x04 bytes @ 0xFFFFFC20 -- WriteRemote(4 bytes @ 0xFFFFFC20) returns 0x00 (0001ms, 0519ms total)
    T0D90 584:425 JLINKARM_WriteU32(0xFFFFFC30, 0x00000009) - Writing 0x04 bytes @ 0xFFFFFC30 -- WriteRemote(4 bytes @ 0xFFFFFC30) returns 0x00 (0001ms, 0520ms total)
    T0D90 584:426 JLINKARM_MeasureCPUSpeed(RAMAddr = 0x00200000) >0x48 JTAG> - Writing 0x08 bytes @ 0x00200000 -- WriteRemote(8 bytes @ 0x00200000)
    ***** Error: Write memory error @ address 0x00200000, word access: Memory access timeout. -- ReadRemote(8 bytes @ 0x00200000) -- Abort occured
    ***** Error: Failed to verify RAMCode for CPU clock frequency detection! (0209ms, 0729ms total)
    T0D90 584:635 returns 0xFFFFFFFF (0000ms, 0729ms total)
    T0D90 584:635 JLINKARM_WriteMem(0x00200000, 0x0800 Bytes, ...) -- Data: FD E7 FE E7 62 E0 7C E0 4B E0 27 E0 0F 25 2C 1C ... returns 0xFFFFFFFF (0000ms, 0729ms total)
    T0D90 584:635 JLINKARM_ReadMem (0x00200000, 0x0800 Bytes, ...) -- Has error -- Data: AA AA AA AA AA AA AA AA AA AA AA AA AA AA AA AA ... returns 0x01 (0000ms, 0729ms total)
    T05CC 584:966 JLINKARM_GetHWStatus(...) returns 0x00 (0001ms, 0730ms total)
    T05CC 585:217 JLINKARM_GetHWStatus(...) returns 0x00 (0001ms, 0731ms total)
    T05CC 585:472 JLINKARM_GetHWStatus(...) returns 0x00 (0001ms, 0732ms total)
    T05CC 585:722 JLINKARM_GetHWStatus(...) returns 0x00 (0001ms, 0733ms total)
    T05CC 585:967 JLINKARM_GetHWStatus(...) returns 0x00 (0000ms, 0733ms total)
    T05CC 586:223 JLINKARM_GetHWStatus(...) returns 0x00 (0000ms, 0733ms total)
    T05CC 586:414 JLINKARM_Close() -- Has error >0x10 JTAG> >0x10 JTAG> (0006ms, 0739ms total)
  • Hi SimonB,
    have you tried the sample project for the AT91SAM7S256 delivered with J-Flash?
    If no: Could you please try out the sample project and test if it works with your board?
