Simultaneous IP over USB and Ethernet Port?
    • Simultaneous IP over USB and Ethernet Port?
      I was wondering if it was possible to configure IP over USB and also an Ethernet port driver simultaneously? It appears that IP_AddEtherInterface can be used for multiple interfaces but I wasn't sure if it could work with IP over USB? If both interfaces can be used simultaneously are there any negative consequences?
    • Hello CodeRunner,
      Using multiple interfaces really is as easy as adding another interface in your IP_X_Config() .
      One thing to take care of:
      Please make sure that you add the real port Ethernet driver first as most of these drivers expect to be interface #0 for internal simplicity and performance.
      Drivers like IP over USB however are written in a way so they can be added at any position in such a combination.
      Oliver
