[ABANDONED] Failed to update bootloader
  • [ABANDONED] Failed to update bootloader
    I am trying to update bootloader on my FRDM-K66F which is in a brick state right now.
    On erase JLink returns error (-1). Loadbin command shows success however the board remains in dead state.
    Thank you,
    Igor
  • Hi Igor,
    Could you please answer the following questions?
    1) How exactly did you "brick" the board?
    2) Does erasing work if you reset the device first?
    1. r
    2. erase
    3) Can you confirm if the data is indeed the correct data after flashing the device?
    4) Does the loadbin command work with a different data file?
    5) Could you please send us a J-Link log file? How to enable:
