I'm using BLUENRG2 device from STM which is Cortex-M0 and having problem with connecting to the target when the device is in sleep. SWD interface is deactivated so I believe that I need to set the reset type to "Connect under reset" which should be reset type 3. I already tried to set "Initial Reset and Halt type" and "Pre-run / Restart reset" in Eclipse debugger /startup settings to 3, but that didn't change anything, it looks like that these options are for reset after connecting to the target (I can see in the logs that J-Link is still using normal reset). I found that there is a "SetResetType" command string, but I didn't find a way how to use it with Eclipse. Could you help me how should I add this command string to the Eclipse plugin settings (probably "Other options")? I also tried J-Link script, but not sure how to add this command string to the script and to which functions. I would appreciate any help with this.
Petr
Petr
