[SOLVED] SES Debugger - Showing Yellow arrow in Disassembly window instead of .c file
  • [SOLVED] SES Debugger - Showing Yellow arrow in Disassembly window instead of .c file
    My issue replicates this thread which was marked as [Closed].
    "I am using SES for ARM version 3.50. The target is a Nordic 52832.
    I can set a breakpoint in the source window and when it occurs the
    yellow pointer is in the disassembly pane. If I single step, the debuggers
    does one assembler statement at a time. Last week the yellow pointer
    was in the source pane and single stepping did one C statement at a
    time. Any idea what I could have changed?"
    I have followed the advice provided (check paths, clean/rebuild) and the paths seems to be correct. I've copied the project folder to another location to see how it would respond to a new path change, but I still run into this result.
    A colleague running out the same repo on a different machine does not have this issue.
    Any pointers would be appreciated. Thank you much.
    Braon
  • Hello Braon,
    Do you see the same behaviour in the latest Embedded Studio version? Please understand that we can't provide support for old Embedded Studio versions.
  • Howdy thank you. I'm on Embedded Studio 4.52. My issue was J-link related actually. Unrelated to the previous thread. Ultimately, the blinky_led project i was loading was for the nRF52832, and the SES was programming the nRF52810 on my eval board (which hosts my j-link). My bad. You can erase this whole thread if you want. Thank you for the reply.
    Happy Debugging!
