[SOLVED]Error writing firmware to device
  • [SOLVED]Error writing firmware to device
    I am using the following commands for programming my NRF52 based custom board:
    nrfjprog -f nrf52 --program fimrware.hex --sectorerase --log
    nrfjprog -f nrf52 --reset
    It was working properly, but suddenly it stopped, and now I get the following log (attached in a file)
    I have also triend using J-Link commander, and I get the following
    loadfile "firmware.hex"
    Downloading file [firmware.hex]...
    Writing target memory failed.
    I am not sure what has changed and what is causing the problem, I hope you can help me with this
    • log.log
      (106.46 kB, downloaded 347 times, last: )
    Please note that nrfjprog is not a SEGGER product.
    Therefore, Support is provided by Nordic Semiconductor and not by SEGGER.
    We recommend using J-Flash, SEGGERs professional production utility, which can be uses with a J-Link Plus or higher.
