Targeting an Appwizard text object through code
    • Targeting an Appwizard text object through code
      Hey all,
      Is there a way to target and update the value of an AppWizard text object through code?
      So far I can only update it using the APPW_SetVarData(), but thats with a hardcoded value from AppWizard . I would like to update the text with a custom value from the code itself.
      Let me know if this is possible, and if so, how I can do this. The examples that come with the Emwin trial does not include any AppWizard applications to demonstrate this.
      Josh
      it is not clear enough in the AppWizard manual.
      You can use the TEXT widget API from emWin to set text to the AppWizard TEXT object. Like:
      1. WM_HWIN hScreen;
      2. WM_HWIN hItem;
      3. hScreen = WM_GetDialogItem(WM_HBKWIN, ID_SCREEN_00);
      4. hItem = WM_GetDialogItem(hScreen, ID_TEXT_00);
      5. TEXT_SetText(hItem, sPath);
      Our plan is to add a general AppWizard API to modify the objects by code.
